How to Split an Order and Create a Shipment on eShipz?
Splitting an order is a common requirement for sellers who need to ship items separately. This is typically used in the following scenarios:
  • Partial Availability: When some items in an order are in stock, but others are back-ordered.
  • Partial Payment: When the customer has paid for only a portion of the order.
  • Separate Locations: When items in a single order are being dispatched from different warehouses or fulfillment centers.
eShipz allows you to easily split a single order with multiple items into multiple shipments.
Prerequisite
  • You can only split an order that contains more than one item. If an order has only one item, it cannot be split.
Step-by-Step Guide to Splitting an Order
Step 1: Navigate to the Orders Page
Log in to your eShipz dashboard and go to the Orders page.
Step 2: Select the Order to Split
Find the order you want to split and click on it to view its details. The order should have a status like "Open" or "Processing." etc
Step 3: Initiate the Split
  1. On the order details page, you will see a list of all the items within that order. Look for an action button, usually labeled "Split Order" as shown in the image. Click on it.
  2. Your order is now split into multiple orders as per the no. of line items in that specific order.
Step 4: Create the First Shipment
A pop-up window or a new section will appear, allowing you to select the items for the first shipment.
  • Select Items: Use the checkboxes next to each item to choose one or more items you want to ship at this moment.
  • Update Package Details: Enter the correct weight and dimensions for the new, smaller package containing only the selected items.
  • Create Shipment: Click the "Create Shipment" button for this set of items.
Step 5: Process the First Shipment
The platform will now create a new, separate shipment for the items you selected. You will be taken to a page to complete the booking for this new shipment, just as you would for any other order:
  • Choose Courier: eShipz will display a list of available couriers
  • Book Shipment: Select your preferred courier and click "Fetch Services" and Generate the label to ship
Step 6: Handle the Remaining Items
After the first shipment is created, the order will be updated. The items you just shipped will be marked as "Shipped," while the remaining items will stay in a "UnShipped" status.
Step 7: Create a Second (or more) Shipment
Follow the same process to create the shipments for the remaining orders.
Important Notes:
  • Each time you split an order, a new shipment ID and AWB number will be generated.
  • This feature is crucial for managing inventory and providing transparency to your customers, who can be notified that their items will arrive in separate packages.
  • Make sure to communicate clearly with your customers if you are splitting their order to manage expectations and avoid confusion.
    • Guide to integrate Zoho Inventory with eShipz
      STEP 1: On the right top corner zoho inventory page we have ‘Settings’ click on that icon [Refer Image No: 1.1] Image No: 1.1 STEP 2: On the Settings page click on ‘Automation’[Refer Image No: 1.2] Image No: 1.2 STEP 3: On Automation page click on ...
    • How to create a Reverse shipment?
      Method-1 Step-1: Sign in to eshipz account Step-2: Go to dashboard and click on the "Orders" Step-3: Under "Orders" section, select "Shipped Orders" Step-4: Choose the specific order for which you want to create a reverse shipment Step-5: On the ...
    • How to create reverse shipment in new UI?
      Method-1 Step 1: Login to eShipz account. Step 2: Navigate to fulfillment and click on order. Step 3: Go to shipped orders page. Step 4: Click on the three dots corresponding to the order you wish to create reverse shipment, then click on create ...
    • How to create shipment for CSB 4 & 5?
      CSB4 - Shipment Creation To cater to the new csb4 requirements, eShipz has come up with a CSB4 checkbox in the Create Shipment page that would enable user to enter additional data required for processing csb4 shipments. Enhancements Bank Account ...
    • How to create shipment & generate AWB?
      This Video guide will help you in how to create shipment & generate AWB with eShipz a multi platform solutions for businesses. Step 1. Sign into your eShipz account Step 2. Go to the dashboard and click on create shipment Step 3. Under create ...
