How to process order for dispatch from unshipped order?
This Video guide will help you in How to process order for dispatch from unshipped order with eShipz. SAAS Shipping Application that provides Best Pre & Post Shipping Experiences for Brands and Enterprise Customers.
Step 1. Sign into your eShipz account
Step 2. On the dashboard and click on orders.
Step 3. Under the orders section, click on Unshipped.
Step 4. Choose the order number and select create shipment above.
Step 5. Fill in the required details and package dimensions as required
Step 6. Select fetch services and choose courier partner.
Step 7. Click on book and generate labels.
Step 8. Now, you can download your label with the AWB number.
    • How to create an order in eShipz UI?
      This article provides a detailed, step-by-step explanation of the complete process for manually creating an order through the eShipz user interface, covering all required fields and actions to ensure the order is created successfully. Step 1: Log in ...
    • Order Sync Issue || Woocommerce
      Step -1: Please use the below URL In case of any query raised for Order Sync issue. Check whether you're getting any data and status for the same. URL: your ...
    • How to Split an Order and Create a Shipment on eShipz?
      Splitting an order is a common requirement for sellers who need to ship items separately. This is typically used in the following scenarios: Partial Availability: When some items in an order are in stock, but others are back-ordered. Partial Payment: ...
    • An order has been canceled on my store, but it's still in eShipz.
      Why a Canceled Order Still Appears in eShipz? When an order is canceled on your store, you may still see it in eShipz. This happens because there is no automated cancellation sync between your store and eShipz. Important Points to Note One-way Sync ...
    • How to create order and edit the order in new UI?
      How to create order? Step 1: Login to eShipz account. Step 2: Navigate to fulfillment and click on order. Step 3: Click on create button. Step 4: You will be redirected to the Create Order page. Enter all the required details and click on Save Order. ...
